Apparemment, ils garantissent 45 min d'autonomie et pour le prix , il doit y avoir une sacrée technologie(Lithium Ion LiFe P04 ) !
La 30Ah a une intensité de 180Amp en pointe , donc suffisant pour un mover
Je ne demande qu' à voir .
Si quelqu'un a une expérience ?
http://www.simpark.eu/index.php?option= ... 57&lang=en
The SimPark Sencell battery on sale in the Netherlands.
Carmo Ltd left, as usual, nothing to chance and has released, after a long period of extensive testing and analysis, the first copies of the Sencell battery for sale.
Carmo Ltd has opted for a 30 and 40 Ampère versions. The 30 amp battery is sufficient to manouvre the caravan (over 40 minutes) but it can also serve as excellent battery board (minimum of 2 days supply for the interior of your caravan). The 40 amp Battery is designed for the real heavy duty work and performs in very exceptional circumstances.
Sencell the battery is supplied with the necessary mounting parts for a professional attachment to the caravan.
The weight of the 30 amp battery is only 4.6kg and the weight of the 40 amp version is 5.8kg. The Sencell comes with a specially adapted 8Ah charger for lithium batteries.
In 6 hours time, the Sencell battery is fully charged. The weight of the charger is only 900g. The weight savings with this new Sencell battery is, compared to a conventional lead / acid battery, approx 22kg.
Sencell accu van SimPark
Technische informatie Download hier de datasheet van de Sencell accu Download
Battery type : Lithium Ion LiFe P04
Capacity (Ah) : 30 Ah.
Nominal load (A) : 80 Amp.
Peak load (A) : 185 Amp.
Weight (kg) : 4,6 kilo
Weight charger (kg) : 0,9 kilo
Dimensions (LxBxH mm) : 175x175x130
Protected against : To high loadcurrent
: To high loadvoltage
: To high current consumption
: To high cell temperature
: To low loadvoltage
: Full discharge
Continuous usage : 40 minutes
Charging via car or solar panel : Yes, contact your dealer
Warranty : 24 months
Lifetime expectancy 2000-2500 loading cycles
